DTNC
Jun 04, 2021Follower
Orbi Mesh Router
I am using the Orbi RBR50 mesh router and need to add a satellite. I do not seem to find any RBR50 satellite anymore but I can find RBS50. Do you know if they are compatible? Thanks.
Jun 05, 2021Guru - Experienced User
compatible with the rbr50 is:
rbs20
rbw30
rbs40
rbs40v
rbs50
rbs50y
Keep in mind, only the 50 series has the 1733mbps backhaul. The others use a 866mbps backhaul.
Some have also used the triband extenders: EX7500/EX7700/EX8000
they work but they don't fully integrate with the system.
