Qaisoon
Aug 24, 2020Aspirant
Orbi mesh routers
Hi everyone,i bought Orbi router but its power adapter indicate in its sticker it works on 100/110v but in my home the power outlet are 220v. I heard from other website it will work but iam not sure.....
Aug 24, 2020Guru - Experienced User
IF you don't see 110/240v on the power adapter sticker, then you'll need to get a dual or universal voltage adpater for the Orbi system.
Mstrbig
Aug 24, 2020Master
You can purchase an inexpensive travel adapter from several vendors that will work. I think I paid $14US for my kit. Can do 120-240 and 240-120.
- QaisoonAug 24, 2020AspirantI did try to power an old router with orbi adapter nothing happen to the adapter realy and the old Hewai router powerd on noramally
