Smilingsallyjun
Mar 26, 2020Aspirant
Orbi mesh spectrum problem
Spectrum had to update and reboot my system. My orbi will not reconnect. I have gone through all the steps numerous times. It does not even recognize that it is plugged into modem. I have never had...
Retired_Member
Mar 26, 2020
Smilingsallyjun wrote:Spectrum had to update and reboot my system. My orbi will not reconnect. I have gone through all the steps numerous times. It does not even recognize that it is plugged into modem. I have never had trouble before.
what type of spectrum gear are you running?
have you tried to simply reboot your entire network?
- SmilingsallyjunMar 26, 2020Aspirant
My spectrum equipment is model # TC8717T. I did rebot and also tried all the suggestions on Orbi app. Nothing has worked so far.
- FURRYe38Mar 26, 2020Guru - Experienced User
Your modem already has a built in router and wifi. What mode is it working in? Router? This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Smilingsallyjun wrote:My spectrum equipment is model # TC8717T. I did rebot and also tried all the suggestions on Orbi app. Nothing has worked so far.
- Retired_MemberMar 26, 2020
I have to ask.....how long have you had your Orbi? Has it ever worked with the Spectrum gear?
Or.....did you buy the Orbi not relazing that as a package, it has its own router?.....and that you would end up with 2 routers? Huh?
Just some questions?
- SmilingsallyjunMar 30, 2020Aspirant
My orbi has worked great with my spectrum until they rebooted it. I know i now have 2 routers. It wasnt a problem until now.
