Smilingsallyjun
Mar 26, 2020Aspirant
Orbi mesh spectrum problem
Spectrum had to update and reboot my system. My orbi will not reconnect. I have gone through all the steps numerous times. It does not even recognize that it is plugged into modem. I have never had...
jimthomas858
Jun 25, 2020Aspirant
Had the same problem. Did everything i could think of to clear not obtaining a DHCP served ip address from the WAN. I even rest back to factory defaults.
Worked with spectrum. They flushed the mac from their cache and everything else.
Direct connect from my computer worked.
Switch back to my old crappy router and it worked......
Returned my Orbi . Really bummed cause it worked great for 12 hours.
- FURRYe38Jun 25, 2020Guru - Experienced User
