singhravik
Oct 06, 2019Guide
Orbi Mesh system (1+2) from Costco with latest firmware 2.3.5.30
Just bought my first Wifi Mesh system which is Orbi Mesh system (1+2). A great deal from Costco, but as soon as I upgraded to latest firmware 2.3.5.30, it became garbage. It disconnects often an...
Oct 07, 2019Guru - Experienced User
Did you perform a factory reset as set up from scratch after applying the last FW update? This is recommended.
Retired_Member
Oct 07, 2019
FURRYe38 wrote:Did you perform a factory reset as set up from scratch after applying the last FW update? This is recommended.
Isn't a new install the same as a factory reset?
The OP has a new system. Once setup,....it downloaded the FW (which is a bad one). To do a factory reset, that will only bring him/her back to where they were.
Needs to revert to an earlier FW.
- singhravikOct 07, 2019Guide
Yes, did reset twice and reloaded the firmware. It was of no help. Same choppiness.
I downgraded to last fw version 2.3.1.60 and evaluating the performance this week.
