singhravik
Oct 07, 2019Guide
Orbi Mesh system (1+2) from Costco with latest firmware 2.3.5.30
Just bought my first Wifi Mesh system which is Orbi Mesh system (1+2). A great deal from Costco, but as soon as I upgraded to latest firmware 2.3.5.30, it became garbage. It disconnects often an...
Oct 07, 2019Guru - Experienced User
A new system may have not come preloaded with v30. if so, then the update would have taken place after they got it up and running. Thus a reset maybe needed.
I've had no issues with v30.
Retired_Member
Oct 07, 2019
FURRYe38 wrote:A new system may have not come preloaded with v30. if so, then the update would have taken place after they got it up and running. Thus a reset maybe needed.
That makes no sense. What update are you talking about (V30 to V30???)...2.3.5.30
Just because you don't have issues with V30 doesn't meant others aren't Not sure you would even admit on here if you did.
- FURRYe38Oct 07, 2019Guru - Experienced User
Yes that version.
I'm not the only with with working Orbi systems with v30 loaded.
What version of FW are you using?
- Retired_MemberOct 07, 2019
FURRYe38 wrote:Yes that version.
well the OP has moved on to a more stable FW.
I never said you were the ONLY one with a working .30
That good then for them. Thought they didn't really vet out v30 with a reset. All is good if it's working for them. All that matters.
We have some that v30 works for and some that it doesn't.
