singhravik
Oct 06, 2019Guide
Orbi Mesh system (1+2) from Costco with latest firmware 2.3.5.30
Just bought my first Wifi Mesh system which is Orbi Mesh system (1+2). A great deal from Costco, but as soon as I upgraded to latest firmware 2.3.5.30, it became garbage. It disconnects often an...
Oct 07, 2019Guru - Experienced User
Yes that version.
I'm not the only with with working Orbi systems with v30 loaded.
What version of FW are you using?
Retired_Member
Oct 07, 2019
FURRYe38 wrote:Yes that version.
well the OP has moved on to a more stable FW.
I never said you were the ONLY one with a working .30
- FURRYe38Oct 07, 2019Guru - Experienced User
That good then for them. Thought they didn't really vet out v30 with a reset. All is good if it's working for them. All that matters.
We have some that v30 works for and some that it doesn't.
- Retired_MemberOct 07, 2019
FURRYe38 wrote:That good then for them. Thought they didn't really vet out v30 with a reset. All is good if it's working for them. All that matters.
Ask the moderators to post a poll here seeking the success rate of 2.3.5.30
Most folks aren't interested in being FW beta testers or vetters.
vetting = troubleshooting.
You can ask them anything.
Good luck.
