singhravik
Oct 06, 2019Guide
Orbi Mesh system (1+2) from Costco with latest firmware 2.3.5.30
Just bought my first Wifi Mesh system which is Orbi Mesh system (1+2). A great deal from Costco, but as soon as I upgraded to latest firmware 2.3.5.30, it became garbage. It disconnects often an...
Retired_Member
Oct 07, 2019
FURRYe38 wrote:Did you perform a factory reset as set up from scratch after applying the last FW update? This is recommended.
Isn't a new install the same as a factory reset?
The OP has a new system. Once setup,....it downloaded the FW (which is a bad one). To do a factory reset, that will only bring him/her back to where they were.
Needs to revert to an earlier FW.
singhravik
Oct 07, 2019Guide
Yes, did reset twice and reloaded the firmware. It was of no help. Same choppiness.
I downgraded to last fw version 2.3.1.60 and evaluating the performance this week.
