singhravik
Oct 06, 2019Guide
Orbi Mesh system (1+2) from Costco with latest firmware 2.3.5.30
Just bought my first Wifi Mesh system which is Orbi Mesh system (1+2). A great deal from Costco, but as soon as I upgraded to latest firmware 2.3.5.30, it became garbage. It disconnects often an...
Retired_Member
Oct 07, 2019
FURRYe38 wrote:Let us know how it turns out.
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
singhravik wrote:Yes, did reset twice and reloaded the firmware. It was of no help. Same choppiness.
I downgraded to last fw version 2.3.1.60 and evaluating the performance this week.
Good trouble shooting practice allows to make one change (FW revision) and determine the results. Then IF necessary look else where.
singhravik
Oct 07, 2019Guide
Isn't this FREE QA (quality testing) by consumers post release! too bad !
I'll avoid Netgear next time.
I hated the NightHawk for same reason.. poor quality and too much on consumers to try out.
- Retired_MemberOct 07, 2019
singhravik wrote:Isn't this FREE QA (quality testing) by consumers post release! too bad !
I believe what you'll find is that NO FW is perfect and ALL manufacturers such as NG are faced with the same problem. You're best bet is if you can find a FW that works for you and keeps your system stable, stay there, don't upgrade. When a new FW does becomes available, read the release notes first to understand what changes are offered. Good luck
