bigmoe80
Sep 25, 2022Guide
Orbi mesh system help
ok so i new to the mesh system i been seeing alot of on the internet so tryng to get much info and knowledge about the system also i read that some people having issues with them connecting to inte...
bigmoe80
Sep 25, 2022Guide
ok so could please help me with more info on how to choose mesh system and i notice some says it works with a certain internet packages speed
ekhalil
Sep 25, 2022Master
A good start is to use the Orbi Product Selector here: https://www.netgear.com/home/wifi/mesh/find-my-orbi/?cid=us-orbi-wifi-system-kb-referral&utm_source=kb&utm_medium=referral&utm_campaign=us-orbi-wifi-system-kb-referral&_ga=2.231784792.650801738.1663128167-1448435326.1663128167
- bigmoe80Sep 25, 2022Guide
ok thanks
so what's this big talk about wifi 6 and wifi 6
- ekhalilSep 25, 2022MasterWifi 6 is the new wifi standard (IEEE 802.11ax).
All new mobile devices (phones, laptops,…) support the new wifi 6. With wifi 6 you get the following main benefits:
1. Higher speeds: Wifi 6 delivers about four times greater wireless performance in congested settings than Wifi 5, thanks to improvements in the directional antenna’s Multiple-in Multiple-out (MIMO) capability.
2. Improved security using WPA3 authentication.
3. Improved battery life for your devices
4. Because of the improved access point capacity, wifi 6 is good when having many IoT devices.
In wifi 6e a new frequency band (6GHz) was introduced beside the existing 2.4 and 5GHz bands.- bigmoe80Sep 25, 2022Guide
ok i see
