ChrisJohnsonDoz
Oct 29, 2021Aspirant
Orbi Mesh System RBR40 Quit Working
My main router just stopped working. I have tried unplugging it to reset it. I have also pressed the reset button. The small green light above the "on/off" button is lit, but the halo on the top will...
CrimpOn
Oct 29, 2021Guru - Experienced User
Sometimes a Factory Reset helps:
https://www.youtube.com/watch?v=cMw4ePACgc4
The key is to hold something in the tiny reset hole long enough (up to 15 seconds)
Bannister59
Oct 30, 2021Aspirant
CrimpOn wrote:Sometimes a Factory Reset helps:
Hello,
This works really well for me, thank you! Facing same issue here. Help is appreciated.
