ChrisJohnsonDoz
Oct 29, 2021Aspirant
Orbi Mesh System RBR40 Quit Working
My main router just stopped working. I have tried unplugging it to reset it. I have also pressed the reset button. The small green light above the "on/off" button is lit, but the halo on the top will...
CrimpOn
Oct 29, 2021Guru - Experienced User
Sometimes a Factory Reset helps:
https://www.youtube.com/watch?v=cMw4ePACgc4
The key is to hold something in the tiny reset hole long enough (up to 15 seconds)
ChrisJohnsonDoz
Oct 30, 2021Aspirant
I have tried this several times, but it hasn’t worked. I’ve held it as long as 2 minutes but the green power light does not change colors, and it will not even do the factory reset. I guess this is Orbi’s way of forcing you to upgrade. Very disappointing!!
- FURRYe38Oct 31, 2021Guru - Experienced User
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
