A_BW5
Dec 16, 2024Follower
Orbi Mesh system, Sky Router and a gigabit switch
Hi, I am looking at the Orbi Mesh system but am concerned it won't be compatible with my set up, (sorry if I get some of the terminology wrong). I currently have DSL internet connected to a Sky Modem...
Dec 16, 2024Guru - Experienced User
I would check with the ISP first to see what they require for connections to there services, and if the router can be changed to modem mode only, if the are any special configurations needed on a external router such as a Orbi system.
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
If a Orbi system is put in place then you would connect the LAN switch behind the Orbi router when used in router mode.
