Samtwo
Mar 31, 2020Aspirant
Orbi mesh systems
I have a Netgear AC1900 WiFi cable router-modem. My ISP is Spectrum. I need to add a mesh WiFi system; the Orbi systems seem like the best choice since they'll be compatible with the existing gear. ...
- Apr 02, 2020
You need 30 feet to start...
Mar 31, 2020Guru - Experienced User
If your modem has a built in router and wifi already, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
You can still use your current modem, just configure it to one of the suggestions above. If it's working well for you, I would try option#3 first. The NG cable modem/router can be bridged for option#1.
Look for what may work best for you for you size of home.
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspx
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
If you have devices that support AX mode then maybe, if not, then Orbi AC will be good for you unless you just want to future proof your house hold.
