Samtwo
Mar 31, 2020Aspirant
Orbi mesh systems
I have a Netgear AC1900 WiFi cable router-modem. My ISP is Spectrum. I need to add a mesh WiFi system; the Orbi systems seem like the best choice since they'll be compatible with the existing gear. ...
- Apr 02, 2020
You need 30 feet to start...
Apr 02, 2020Guru - Experienced User
Any progress on this?
Samtwo wrote:I have a Netgear AC1900 WiFi cable router-modem. My ISP is Spectrum.
So I'll apreciate help in clarifying some points -
1) Do I need to replace the AC1900 or is it possible for the Orbi to plug into the modem?
2) The coverage is for a ~2,500 sqf home plus outdoors. Should I get a 2 or 3 component system?
3) Should I go with a WiFi 6 system or is it an overkill?
Thanks, Sam
- SamtwoApr 02, 2020Aspirant
Thanks for the help. Yes, there's progress - my Netgear cable router-modem can be set in bridge mode.I have ordered the Orbi RBK50V, a 2 pack with Alexa built-in. I may need a second satellite; this will bedetermined after the 2 pack is installed.
This sytem is now at a discount so grab it if you need something like that.
Sam
- FURRYe38Apr 02, 2020Guru - Experienced User
Sounds good. Review the placement suggestion when yout get your system in and start setting it up.
The placement is not flexible, unfortunately. The cable comes in in a far corner of a 2 story home so the new router will need to be placed close to it unless I choose to go with a very long Ethernet cable, not a good option. The satellite will be downstairs and a second one may be needed.
