Samtwo
Mar 31, 2020Aspirant
Orbi mesh systems
I have a Netgear AC1900 WiFi cable router-modem. My ISP is Spectrum. I need to add a mesh WiFi system; the Orbi systems seem like the best choice since they'll be compatible with the existing gear. ...
- Apr 02, 2020
You need 30 feet to start...
Samtwo
Apr 02, 2020Aspirant
Thanks for the help. Yes, there's progress - my Netgear cable router-modem can be set in bridge mode.I have ordered the Orbi RBK50V, a 2 pack with Alexa built-in. I may need a second satellite; this will bedetermined after the 2 pack is installed.
This sytem is now at a discount so grab it if you need something like that.
Sam
Apr 02, 2020Guru - Experienced User
Sounds good. Review the placement suggestion when yout get your system in and start setting it up.
- SamtwoApr 02, 2020Aspirant
The placement is not flexible, unfortunately. The cable comes in in a far corner of a 2 story home so the new router will need to be placed close to it unless I choose to go with a very long Ethernet cable, not a good option. The satellite will be downstairs and a second one may be needed.
- FURRYe38Apr 02, 2020Guru - Experienced User
Just be sure that 30 feel is minimum starting distance. Any closer can cause too much wifi over lap in signal between the RBR and RBS and degrade operation and performance.
OK, this is then what you meant by placement. It will be at least 20 ft. Same for a second satellite, there will be at least 20 ft between any two units.
