ZanL
Jan 25, 2021Tutor
Orbi Mesh Triband won't connect to my HP Officejet 8740
Can anyone help me to get my HP printer to connect to my Orbi? I just spent 2 hours on Netgear tech support.... They could not fix my problem. I changed the 2.4 ghz channel to 11. Nothing... I w...
- Jan 26, 2021
I just armwrestled with my HP Envy printer. One of the steps in curing the problem was to delete the network information from the printer, shut it down and unplug it for 30 seconds or so. (If you pray, it can't hurt to do this during the wait. No, I don't have a good prayer for a printer. đ„ž) Plug it back in and start all over.
Amid the sophistification of this forum, please forgive these simple recommendations.
vajim
Jan 25, 2021Master
ZanL wrote:Can anyone help me to get my HP printer to connect to my Orbi? I just spent 2 hours on Netgear tech support.... They could not fix my problem. I changed the 2.4 ghz channel to 11. Nothing... I was told to go to the advanced tab for the router and on the WAN setup, open the NAT filtering... I did and nothing. I am good with computers, but not experience with network problems.
The printer connects to the orbi not the other way around
how far is the printer from the orbi router?
does the printer have a network setup built in?
vajim
Jan 26, 2021Master
