Danielworks
Sep 19, 2020Follower
ORBI Mesh upload getting slower after a week
Hi there, My ORBI Mesh system (router + 2 satellites) has a wired problem. The router upload speed only reach 80MBps when the fibre is capable for 400MBps. I've done the search across for...
Mstrbig
Sep 20, 2020Master
Who is your ISP and what equipment did they provide?
What is the current firmware on your Orbi device?
What device is your Orbi router connected to?
Did you reboot your ISP modem/router, before starting the Orbi router install?
Have you changed the network cable connected from the ISP device to your Orbi router? If cat5, you need to change to at least cat5e
Disable Circle, Armor, Daisy Chaining, Fast Roaming, IPv6 and uncheck 20/40Mhz Coexistence.
Enable WMM, Implicit BeamForming, Mu-MIMO
Set Short preamble mode. Save settings, reboot Orbi.
