mun_96
Apr 07, 2020Guide
Orbi mesh want 5Ghz only
I purchased an Orbi mesh system (RBK50 which comes with one satellite and one router). It works brilliantly when my devices are on 5GHz and I get my full internet speed. Sometimes, however, my devi...
Apr 08, 2020Guru - Experienced User
Be aware that its up to wireless devices to pick and choose which frequency and single they connect too based on signal, noise and conditions. Orbi only provides the platform to connect to.
mun_96
Apr 08, 2020Guide
thanks FURRYe38 . I was thinking the ORBI was the one switching the devices to other bands, but what you say about the devices makes sense. CrimpOn has a point as well though that the access point could potentially be communicating to a device that it may be better for them to switch to another band. You 2 are clearly more knowledgeable than me but I am going to try the suggestion by CrimpOn to turn down power transmission on 2.4Ghz band.
- mun_96Apr 08, 2020GuideJust as an update, turned 2.4Ghz transmission down in steps. 75% not much difference. At 50%, some devices were still trying to cling on to 2.4Ghz which was giving a speed of around 15 Mb/s . Turned it to minimum 25% and seems to have reduced the device cling over the past hour or so. Most devices now on 5Ghz on 300Mb/s +, occasionally one or two may stray back to 2.4Ghz but check later and they're back on 5 GHz.
Thanks! - FURRYe38Apr 08, 2020Guru - Experienced User
Hope that works well for you.
Cheers. :smileywink:
