mun_96
Apr 07, 2020Guide
Orbi mesh want 5Ghz only
I purchased an Orbi mesh system (RBK50 which comes with one satellite and one router). It works brilliantly when my devices are on 5GHz and I get my full internet speed. Sometimes, however, my devi...
mun_96
Apr 08, 2020Guide
thanks FURRYe38 . I was thinking the ORBI was the one switching the devices to other bands, but what you say about the devices makes sense. CrimpOn has a point as well though that the access point could potentially be communicating to a device that it may be better for them to switch to another band. You 2 are clearly more knowledgeable than me but I am going to try the suggestion by CrimpOn to turn down power transmission on 2.4Ghz band.
mun_96
Apr 08, 2020Guide
Just as an update, turned 2.4Ghz transmission down in steps. 75% not much difference. At 50%, some devices were still trying to cling on to 2.4Ghz which was giving a speed of around 15 Mb/s . Turned it to minimum 25% and seems to have reduced the device cling over the past hour or so. Most devices now on 5Ghz on 300Mb/s +, occasionally one or two may stray back to 2.4Ghz but check later and they're back on 5 GHz.
Thanks!
Thanks!
- FURRYe38Apr 08, 2020Guru - Experienced User
Hope that works well for you.
Cheers. :smileywink:
