evankovanis
Mar 15, 2022Aspirant
Orbi Mesh Wifi 6 Consistent Intermittent Internet-Drops Out every 3-10 minutes
I have the following system: Orbi Mesh WiFi 6 System with Built-in DOCSIS 3.1 Cable Modem - AX4200 - 2 pack (CBK752) My internet connection drops every 3-10 minutes. I have called my ISP (Spectr...
Mar 15, 2022Guru - Experienced User
you have a screen snip of the cable connections page and event logs?
evankovanis
The event log is below, I don't know what the "cable connections" page is, can't find it in the web interface.
- plemansMar 16, 2022Guru - Experienced User
The cable connections page will show upstream/downstream info. When you first log into the device, click on the internet icon on the home page. (through the gui)
Your logs are indicating a line issue currently.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
