Pmartinez348
Sep 19, 2018Aspirant
Orbi mesh WiFi and concrete walls
I am planning on upgrading my WiFi system (nighthawk ac1900) to Orbi mesh WiFi with sat.
But I wanted to make sure this will work on a two story concrete house. Can you please provide your inputs. ...
Sep 20, 2018Guru - Experienced User
Pmartinez348 wrote:But I wanted to make sure this will work on a two story concrete house. Can you please provide your inputs.
Can you give us some information on the coverage your Nighthawk is giving you? If it is reasonable, then Orbi would work. But if it can't penetrate the walls at all, then Orbi likely won't either.
- Pmartinez348Sep 20, 2018AspirantNighthawk works fine on first floor, then I have an extender fir the second floor, it works fine. The main reason I am planning an upgrade is to get a higher power single and a single network thru the house and patio. Can you provide some recommendations?
I have about 8 wireless devices connected wirelessly and 6 ethernet.
Thx
Pedro- StephenBSep 20, 2018Guru - Experienced User
How fast is your internet service? Are you using your wifi mainly to connect to the internet, or are you using it to connect to your ethernet devices?
Pmartinez348 wrote:
Nighthawk works fine on first floor, then I have an extender fir the second floor, it works fine.Ok, then an Orbi would also work. The RBK50 would give you the best wifi backhaul between the router and the satellite. Normally that's recommended for larger spaces, but it might be the right option for you given the concrete construction. It should give you more flexibility on placement of the satellite, which might be helpful in maximizing your coverage.
If you have ethernet to the second floor, you can also use ethernet backhaul with the Orbi.
You could add a second satellite later on if that is needed to get to the patio.
- Pmartinez348Sep 20, 2018AspirantMy internet is 100 mbs
I use wifi for streaming and apple devices.
Apple TV and NVidia Streaming Box are connected to Ethernet
Thanks
