Pmartinez348
Sep 19, 2018Aspirant
Orbi mesh WiFi and concrete walls
I am planning on upgrading my WiFi system (nighthawk ac1900) to Orbi mesh WiFi with sat.
But I wanted to make sure this will work on a two story concrete house. Can you please provide your inputs. ...
Sep 21, 2018Guru - Experienced User
30 feet is recommended in between the Orbi router and satellite(s) to begin with depending upon building materials. Being that you say the building materials is concrete, the distance between base router and satellite(s) will probably need to be closer.
Your usual response will be greatly appreciated.
P Martinez
