pradones
Oct 05, 2021Aspirant
Orbi Mesh Wifi is not connecting to with Blink Sync Module
I have an Orbi RBR50 with two satellites set up in my home. I am not able to connect the Blink Sync Module (Blink Cameras) resulting in the inability to connect the camera system to my wifi and rende...
pradones
Sorry I did not mean to confuse you, when I start the process the blue light is on and the green light is blinking, I am able to identify the system and begin entering the wifi and password, after a few seconds of trying to connect I get the red light which lets me know it did not work.
CrimpOn
Oct 05, 2021Guru - Experienced User
I am confused all the time. I was pretty sure it said green light ON and blue light blinking, but 'no matter'
So we are on step 7, choosing a WiFi system. You select the Orbi WiFi by pressing on the name, and move on to step 8 where the password is entered. This is like the 9th level of Hell for my fat fingers. At least Blink has a way to display the password that was entered (and not persist in showing 'dots'). The password is the Orbi WiFi password, not the web interface administration password.
If it fails the same way again after doing a 'reset' (I have a 'special' paperclip for this because I do it so often.), my next step would be to try it on a different WiFi network. Like the Orbi Guest WiFi.
