tummie93
Feb 24, 2020Tutor
Orbi mesh wifi vs Centurylink Fiber Optic = Orbi win
How to install Orbi mesh wifi with Centurylink Fiber Optic Call Centurylink for your pppoe username and password and vlan number which is (201) Have laptop and ethernet wire Log on to orbilogi...
tummie93
Feb 25, 2020Tutor
That's not the case for me. There was no prompt to update the firmware. I couldn't connect onto the orbi wifi and kept running into issue. I had to restart the whole process. Had to do step 1 and all the way to step 11 before the Orbi router connected. To update the firmware I was still connected to my old CL router. Once the firmware was updated, Vlan showed up in the Orbilogin.net therefore i was able to log on and change the Vlan to 201 or else nothing will work.
tummie93
Feb 25, 2020Tutor
I prob missed a step...
If firmware is not up to date. Need to connect back to CL router for wifi access to update firmware.
- AnonymousFeb 25, 2020
tummie93 wrote:I prob missed a step...
Seems like a lot of work using the ISP. My case with Cox, just swapped out old router and took off.
Thanks for the explanation. :smileyhappy:
