tummie93
Feb 24, 2020Tutor
Orbi mesh wifi vs Centurylink Fiber Optic = Orbi win
How to install Orbi mesh wifi with Centurylink Fiber Optic Call Centurylink for your pppoe username and password and vlan number which is (201) Have laptop and ethernet wire Log on to orbilogi...
cboglio
Mar 23, 2020Aspirant
I followed the instructions above how it wont connect to the internet. I have the PPPoE credentials from Centurylink and inputed the information. I also did the VLAN 201 tagging.
Any thoughts?
tummie93
Mar 23, 2020Tutor
U sure the router and both satellite software is updated?
- cboglioMar 23, 2020Aspirant
tummie93 wrote:
U sure the router and both satellite software is updated?Yes. I checked in both the Orbi app and online router config page.
V 2.5.1.8
Im at a loss.
does IPv6 vs IPv4 make a difference? The current CL CZ3000 router shows an IPv4 address, but nothing for IPv6. However IPv6 is the only option on the Orbi advanced settings page.
Could that the issue?
- FURRYe38Mar 24, 2020Guru - Experienced User
Be sure the ISP modem is fully bridged.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
cboglio wrote:does IPv6 vs IPv4 make a difference? The current CL CZ3000 router shows an IPv4 address, but nothing for IPv6. However IPv6 is the only option on the Orbi advanced settings page.
- Retired_MemberMar 24, 2020
cboglio wrote:
V 2.5.1.8
Im at a loss.
This is your problem: V 2.5.1.8
Get rid of it
- cboglioMar 24, 2020AspirantWhat do you mean get rid of it? What’s wrong with the version? Is there a newer? Do I need to downgrade? Is that possible?
