tummie93
Feb 24, 2020Tutor
Orbi mesh wifi vs Centurylink Fiber Optic = Orbi win
How to install Orbi mesh wifi with Centurylink Fiber Optic Call Centurylink for your pppoe username and password and vlan number which is (201) Have laptop and ethernet wire Log on to orbilogi...
tummie93
Mar 23, 2020Tutor
U sure the router and both satellite software is updated?
cboglio
Mar 23, 2020Aspirant
Yes. I checked in both the Orbi app and online router config page.
V 2.5.1.8
Im at a loss.
- cboglioMar 23, 2020Aspirant
does IPv6 vs IPv4 make a difference? The current CL CZ3000 router shows an IPv4 address, but nothing for IPv6. However IPv6 is the only option on the Orbi advanced settings page.
Could that the issue?
- FURRYe38Mar 24, 2020Guru - Experienced User
Be sure the ISP modem is fully bridged.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
cboglio wrote:does IPv6 vs IPv4 make a difference? The current CL CZ3000 router shows an IPv4 address, but nothing for IPv6. However IPv6 is the only option on the Orbi advanced settings page.
- cboglioMar 24, 2020AspirantI don’t want to bridge. I rather replace CL C3000z modem and run the ONT directly into the Orbi RBK50
- Retired_MemberMar 24, 2020
cboglio wrote:
tummie93 wrote:
U sure the router and both satellite software is updated?Yes. I checked in both the Orbi app and online router config page.
V 2.5.1.8
Im at a loss.
This is your problem: V 2.5.1.8
Get rid of it
- cboglioMar 24, 2020AspirantWhat do you mean get rid of it? What’s wrong with the version? Is there a newer? Do I need to downgrade? Is that possible?
