tummie93
Feb 24, 2020Tutor
Orbi mesh wifi vs Centurylink Fiber Optic = Orbi win
How to install Orbi mesh wifi with Centurylink Fiber Optic Call Centurylink for your pppoe username and password and vlan number which is (201) Have laptop and ethernet wire Log on to orbilogi...
jhoff909
Apr 23, 2020Apprentice
Newest firmware seems to help (2.1.5.16) but I'm still not getting gigabit speeds in both directions wired directly to the Orbi router. Generally get 700/200 or so.
Apr 23, 2020Guru - Experienced User
I would try a factory reset on the RBR. Setup from scratch. Power OFF the ISP modem/ONT for 1 minuted then back on. Be sure to not enable QoS, Traffic Meter, Access Controls, Armor or Circle on the RBR after completing the setup wizard. Be sure to use Ooklas installable speed test app to speed test with. Web page broswers can give inaccurate speed results.Try a different wired PC to compare speeds.
Just took a speed test with my RBR50 loaded with v2.5.1.16:
jhoff909 wrote:Newest firmware seems to help (2.1.5.16) but I'm still not getting gigabit speeds in both directions wired directly to the Orbi router. Generally get 700/200 or so.
