tummie93
Feb 24, 2020Tutor
Orbi mesh wifi vs Centurylink Fiber Optic = Orbi win
How to install Orbi mesh wifi with Centurylink Fiber Optic Call Centurylink for your pppoe username and password and vlan number which is (201) Have laptop and ethernet wire Log on to orbilogi...
Apr 23, 2020Guru - Experienced User
So were you in the beta program for NG?
Seen various posts with users not being able to attain anything near 900Mpbs on PPPoE services. Something that a reset may not fixd. My ISP is cable and they don't use PPPoE. All DHCP.
Factory resets are a last resort and valid to help check and clear out any misconfigurations over time. Also any lingering prior FW code that may have not been fully cleared out during a FW update.
One thing to do is to have a backup configuration to file handy so if a reset is needed, this saves time.
Any chance you have a friend or family member around where you can test the RBR on a non PPPoE connection?
jhoff909 wrote:Hi Furry - I may try the factory reset. I am using that same app on the wired, connected computer and I've tried it with 2 different computers with a similar result. I did try the factory reset with the previous firmware (2.5.1.8 - actually it was a beta firmware 2.5.2.8 or something like that. hardware was also beta hardware - RBR50v2 hardware although I believe it's the same hardware that eventually got released. I believe we were testing the software, not the hardware). What I'm really curious to find out is if *ANYONE* had been able to get gigabit speeds in both directions with PPPoE. I haven't been able to find any posts that shuggest they have.
jhoff909
Apr 23, 2020Apprentice
FURRYe38 wrote:So were you in the beta program for NG?
Yes, I was on a NG beta program via Centercode and have been for years. I've tested other NG routers (R6300, RE6300) and some Linksys ones (EA8500) too. I suspect the Orbi is just not up to the task... I also have Cindy and Vic from Netgear's attention via e-mail - they were helping me with the connected device issues and are interested in the speed issues as well but they have been silent about it of recent. I'm currently using the Orbi as my router, one RE6300 in my office to provide wired access (I have the extended wireless turned off) to computers and a printer in my office, another RE6300 in my garage running as a regular wifi extender to provide wifi for a wireless security camera.
- FURRYe38Apr 23, 2020Guru - Experienced User
Ok, kewl. Well something to keep in touch with them about if you are in contact with them. PPPoE has been problematic for years, not only with NG products. ALso see lot of problems with ISP Gateway modems as well. Mostly ATT and Arris BG models.
- jhoff909Apr 23, 2020Apprentice
I will likely add the C3000Z back in as the router and use the Orbi in AP mode... just have to have time to do it and not disrupt the network for the rest of the house.
FURRYe38 wrote:Ok, kewl. Well something to keep in touch with them about if you are in contact with them. PPPoE has been problematic for years, not only with NG products. ALso see lot of problems with ISP Gateway modems as well. Mostly ATT and Arris BG models.
Let us know how that turns out.
