rsweiner
Mar 21, 2020Follower
Orbi mesh WiFi
Does the Orbi ac3000 mesh WiFi include a modem/router or do I buy that separately?
Mar 21, 2020Guru - Experienced User
RBK systems dont not have a built in router. The CBK system has a built in cable modem.
If you want to get a RBK system, you'll need to get a separate modem to use. A stand alone modem is prefered if you use a RBK system with it.
