nbgcs
Feb 07, 2021Aspirant
Orbi Mesh?
I currently have a system of 4 TP-Link (TL-WR 841N ver 8.4) wireless routers providing Wi-Fi throughout my home. They have become unreliable, lost password protection, etc and I have a feeling that t...
Feb 07, 2021Guru - Experienced User
Those are some pretty basic routers/ap's you're using currently.
How big/long is the current home? What are the interior walls made of?
I'm a fan of the triband orbi's. they have better throughput, lower latency than the dual bands.
And if you're using satellite, you're probably not getting a ton of bandwidth so its still important to retain the bandwidth that you have.
- nbgcsFeb 20, 2021Aspirant
Thanks for getting back to me.
The house is long, so about 30m from one end to the other, 2500 sq ft total area. The middle section is old and has 2 ft thick stone walls. So not an easy property to to get connected, although the current set up is ethernet cabled. The feed from the satellite is at one end, so it is quite a distance to the far end.
Any suggestions for a more stable set up would be greatly appreciated.
Thanks
- CrimpOnFeb 20, 2021Guru - Experienced User
As you already know, WiFi signals will struggle with 2ft. stone walls. Almost any brand of "mesh" WiFi will provide a seamless network as long as every access point is connected to the main router with ethernet cable. It's the ethernet 'backhaul' that is key. Many popular inexpensive mesh systems do not provide ethernet jacks on the satellite units.
