hariou
Dec 12, 2019Aspirant
orbi micro vs big brother
Hi If on a wired backhaul. whats the range difference between micro and 3000 version?
hariou
To clarify, the range of clients to the satellite or router.
The antennas seem bigger, thus I would expect a longer range.
Dec 12, 2019Guru - Experienced User
Usually 30 feet is a starting point between the RBR and RBS when wirelessly connected. This sets a good wifi signal over lap between them. Some have have them well beyond this as well. Say 60 feet. However this is between the RBR and RBS.
Different devices have different radios and receivers. Depending upon how well they are designed, will dectate on how well they can receive and connect.
