hariou
Dec 12, 2019Aspirant
orbi micro vs big brother
Hi If on a wired backhaul. whats the range difference between micro and 3000 version?
CrimpOn
Dec 12, 2019Guru - Experienced User
It would help if you identify specifically what "micro" refers to. The new RBK12 system (the "little cubes") is not capable of ethernet backhaul. The satellites have no ethernet port. https://www.netgear.com/images/datasheet/orbi/RBK12.pdf
I am not aware of any published signal strength vs. distance comparisons of the different Orbi models.
