houtex62
Dec 31, 2018Aspirant
Orbi Mini and Samsung TV connection issues
I recently installed the Orbi Mini in my home and for the post part it works well. But I'm having an issue connecting my Samsung smart TVs. They will not connect to my main Orbi wireless network SS...
JoeCymru
Dec 31, 2018Virtuoso
I assume you have told your TV's to forget their previous network. For good measure, after you have told your TV's to forget their network hook up, reboot the TV's (power plug pull, 30 sec, plug in) and then in Orbi disable the guest network or at least disable the SSID broadcast.
Go through the internet set up again with your Samsung TV's (you may have to refresh the Samsung host server).
