Yuyux
Apr 01, 2018Follower
Orbi Mini RBR20
I recently bought a Orbi mini pack (1 router and 1 satellite) from Costco. The model is RBR20 for the router and RBS20 for the satellite. Both with the latest firmware v2.0.0.64. Great cover for ...
Apr 02, 2018Guru - Experienced User
There should be only one SSID after you complete the set up.
Where are you seeing these SSIDs?
Try a factory reset on both router and satellite then set up from scratch. Give a new SSID name. Make it different this time.
Does the same thing happen after setting up?
