wilson111
Jan 07, 2019Follower
Orbi Mini Router RBR40 Not Broadcasting Signal
Orbi Mini Router RBR40 is no longer broadcasting signal -- unsure as to the cause.
The only light that turns on when I plug in the power is the green power light – the ring for indicating the r...
Patricknew
Feb 26, 2019Aspirant
I, too am having the same issue after a prolonged power outage. I've tried all of the reboots, etc, but cannot seem to get the thing to do anything but have the green light turn on at the back. The top never turns colors. Blanca_O any ideas?
- FURRYe38Feb 26, 2019Guru - Experienced User
I would contact NG support for an RMA...
- Blanca_OFeb 27, 2019NETGEAR Employee Retired
Hi Patricknew
This appears to be a possible hardware problem.
Do you have a device wired to router? If so, can you please check the Ethernet / Local Area Connection status? Is it saying "Network cable unplugged"? "Unidentified Network"? "Not Connected"?
Can you still access the router settings page? When did the issue start?
Blanca
Community Team- PatricknewFeb 27, 2019AspirantI’ve tried hooking up a computer via Ethernet and I still cannot access the settings of the router. I’ve tried factory resetting it per the support pages - the green light next to the power cable never turns Amber and the ring will never light up. This all began yesterday after a power outage that lasted 4 hours. Thanks!
