Leesie424
Dec 08, 2019Aspirant
ORBI Model RBK22
I have an ORBI Router and Satellite. The Satellite is not lit or blinking except when I reconnect it after disconnection. 1)How do I know it’s working? 2)What is the purpose of the Satellite? 3)Can...
Dec 08, 2019Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
3)Can I use the Satellite upstairs if the main ORBI Router is downstairs?
