AnnieBelle
Jun 17, 2020Follower
Orbi Model RBK50 When syncing the satellite does the light pulse on stay on steady when synced?
I am having a hard time connecting my robot vac to the internet. and I am wondering if the satellite orbi is synced with the main router. I get a blue color but it is pulsing and not staying on ste...
Jun 18, 2020Guru - Experienced User
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
AnnieBelle wrote:I am having a hard time connecting my robot vac to the internet. and I am wondering if the satellite orbi is synced with the main router. I get a blue color but it is pulsing and not staying on steady. What am I doing wrong. Our tvs are connected ok.
