davidhard
Mar 14, 2020Aspirant
Orbi (model# RBR50) keeps dropping connection during Zoom calls
Hi, We have two people in our household who work from home from time to time and need to make Zoom calls from time to time. We have now been required by our jobs to work from home for the indefinite ...
Mar 15, 2020Guru - Experienced User
Just curious, what FW version are you using?
DudeDad wrote:The fact that your AppleTV is giving you connection messages and you are seeing a degraded signal suggest that either your RBR50 has an issue, your modem does, or it's an ISP issue. I have a new RBR 50 with 4 satellites. Streaming wirelessly is aournd 500Mbps, and no drops on our AppleTV at all. I have not tried Zoom yet, but will soon.
DudeDad
Mar 15, 2020Apprentice
The latest firmware: V2.5.1.8
Do you have a guest network set up? If so, delete it and see if that helps.
- davidhardMar 17, 2020Aspirant
No guest network setup.
My firmware is up to date. But some are suggesting that it's the latest FW version has stability issues?
Not sure how I can do anything about that.
