AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
Mar 09, 2018Guru - Experienced User
"If it works, don't fix it."
LoL:smileyvery-happy:
rh0diumwrote:Hey Guys,
Thanks so much fo the update. Is it your belief the the 2.1.x firmware bugs reported on this forumn are all centered on this backhaul connectivity? In other words if you are not using ethernet backhaul (or promise to not touch those settings) could you safely upgrade? Are there other fixes in 2.2 that I should wait for?
I'm on V2.0.1.4 with RBR50 and and have had NO issues. While I understand the frustration of some users I am not one of them and am happily using it in a mixed environment (Windows, Mac, Linux, iOS, TvOS, Camera, Security, Nest, IoT, etc.).
FYI: I really want to use the circle features but have been hesitant to roll foward?
lbdyck
Mar 09, 2018Star
After challenges nearly all day today, including a call to support who wanted me to setup a guest network to see if it had the same problem (it did). I have given up. I went to Best Buy and picked up a Linksys Velop, brought it home, plugged it in, downloaded the Linksys app, and it installed and is working perfectly. The Orbi is back in its box to be returned to Costco tomorrow morning.
