AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
bmcguirk
Mar 12, 2018Initiate
AmitR, is there anyway for you to post a download URL for the Beta so those of us willing to take the risk and try it out can, while we wait for the final version to be published?
If not, do you have a general idea of timing - (A couple of days? A few weeks?)
Thank you for continuing to work on this! I suffer from 6-8 drops in an 9 hour work day, so it's been frustrating and I'm looking forward to see if this fixes my issues.
bbunge
Mar 12, 2018Star
bmcguirkwrote:AmitR, is there anyway for you to post a download URL for the Beta so those of us willing to take the risk and try it out can, while we wait for the final version to be published?
While it would be great for Netgear to publish a link to this Beta software I doubt it will happen. Yes, there are an increasing number of folks that are packing up their Orbi to return it or just get rid of it. I got mine because the prior owner had had enough of failures. I've decided to bang away at it and get it to work so I can, in time, give it to someone who needs it.
In the meantime I have loaded firmware starting with the initial 2.0 release, upgraded that to the "current" version, then to the 2.1 latest and finally to the 2.2 Beta. I have done this several times including factory reset between versions. I have not experienced any of the reboots or disconnects on any version. I have experienced network lockups going from WIFI backhaul to Wired backhaul in both the 2.1 and 2.2 versions that corrected itself after a few minutes. Am not too pleased that the WIFI backhaul does not shut down when the wired backhaul is connected. Have experienced a slight drop in throughput with ORBI both wired and WIFI (2.4 and 5 GHZ). Don't feel Disney Circle is great because if you do not have an iOS or Android portable you can't use it (Yes Virginia, there are homes that do not have smart phones!!!). There are other things I don't like about Orbi that I could live without. Netgear is a good company. Sure hope they get this product running great, SOON!
