AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
mpf541
Mar 14, 2018Apprentice
Its so nice since Sunday my network has been rock solid. No problems at all. I put the orbi on a shelf and stared using a velop. With luck netgard will lean how to fix this issue and i can return the velop. But not counting on it.
GTPprix
Mar 14, 2018Star
Any more updates?
I've got what I believe is the top of the line system (the RBK53) and I even bought another RBW30 for my garage and I have to be completely honest; This system sucks. Tons of throughput issues/lag/disconnects/ethernet backhaul crashes if you hook up to the WAN port in AP mode, tries to assign the satellties an IP on a completely different subnet (and a dupe no less!) but I had to plug into the WAN port to turn off the damn magenta light lol Heck even wiht eth backhaul off and the WAN port hooked up response time is notably slower for some reason. So long story short if I dont see something with an actual commitment here IE We will have this firmware out by X date I'm taking all $600 worth of this stuff back.
