AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
DerAusgewandert
Mar 16, 2018Star
hmm, reading all these negative posts I'm betting paranoid that I might end up in the same situation. Currently I have no issues. I am not using the backhaul feature - which is likely the main reason for not having issues. I have one day left to return it and get a Velop instead. I am torn....I might need that backhaul eventually.
It seems those of you who switched believe you've made the right choice. The evidence in better customer support and warranty seems to speak for a switch. There has been no update since the OP on the subject, while it sounded like they are close to a solution. Maybe tomorrow I'll be throwing dice.
- Chairman007Mar 16, 2018StarI’m way past my return period as I’ve had my system since the beginning. It was very stable, however as of the last month or so, it deteriorated to requiring multiple reboots daily, even with a full factory reset and the firmware dialed back to the last known “safe” level. Buffering, stability loss ... absolutely nuts. I bought a 3 mesh Tenda Nova MW6 for $139 and it rocks ... 0 loss, no buffering all over wireless backhaul even though Ethernet is supported. Slight speed loss is nothing compared to the stability gain.
- JMU1998Mar 16, 2018Luminary
Is it more stable running Orbi in AP mode? or Beta has improved stability?
- DerAusgewandertMar 16, 2018Star
ok, since I cannot edit my own post above..
I decided to start the return process tomorrow and ordered the Velop which will arrive Sunday. I have a week to compare the two before I have to ship the Orbi back. I will then make the decision which one to keep.
Cheers
- timchMar 17, 2018LuminaryMy Orbi has been rock solid since 2.1.18, up over 50 days now and I get amazing speeds from both router and satellite (connected by Wi-Fi) I contribute this to add a little balance to the conversation.
- StarbuckyMar 17, 2018Apprentice
I have similar circumstances. I've had my RBK50 for three weeks now and only experienced wifi disconnects (multiple clients) last saturday and then a random reboot last sunday morning. I have one week left to return the system and I am considering going out today to guy a Velop 3 pack. I have been waiting for a few days to get access to the beta firmware and after I agreed to the NDA or whatever I haven't heard back and all my follow-ups have gone un-answered.
Even though i've only had a couple glitches I don't want to take chance that after next week my system will start to drop wifi and start rebooting as is the case for other Orbi owners who've owned their systems for a longers period.
We really like Circle and I'm going to have to drop another $130CAD on the Circle device and attach that to the Velop solution...which alltogether will end costing a bunch more than the RBK50.
Anyway I'm tired of worrying about whether to return or not. I just hope I don't run into issues with the Velop.
- snaptopixelMar 17, 2018TutorAFAIK the Circle device only has a 10/100 Ethernet port so your speeds will be maxed out at 100mbps, that was the whole reason I bought the Orbi instead. Would love to get a hold of the beta firmware to get Circle going. Router is working fine otherwise
- mpf541Mar 17, 2018Apprentice
I also had no problems for 9 - 10 months. And then they added more features. And then the disconnects started.
They must be aware of this as they only want to give 90 days of support before you have tp pay.
