AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
DerAusgewandert
Mar 16, 2018Star
hmm, reading all these negative posts I'm betting paranoid that I might end up in the same situation. Currently I have no issues. I am not using the backhaul feature - which is likely the main reason for not having issues. I have one day left to return it and get a Velop instead. I am torn....I might need that backhaul eventually.
It seems those of you who switched believe you've made the right choice. The evidence in better customer support and warranty seems to speak for a switch. There has been no update since the OP on the subject, while it sounded like they are close to a solution. Maybe tomorrow I'll be throwing dice.
Chairman007
Mar 16, 2018Star
I’m way past my return period as I’ve had my system since the beginning. It was very stable, however as of the last month or so, it deteriorated to requiring multiple reboots daily, even with a full factory reset and the firmware dialed back to the last known “safe” level. Buffering, stability loss ... absolutely nuts. I bought a 3 mesh Tenda Nova MW6 for $139 and it rocks ... 0 loss, no buffering all over wireless backhaul even though Ethernet is supported. Slight speed loss is nothing compared to the stability gain.
- JMU1998Mar 16, 2018Luminary
Is it more stable running Orbi in AP mode? or Beta has improved stability?
