AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
altonf
Mar 18, 2018Initiate
I have been experiencing very irritating internet connection loss multiple times during the day on both satellites since 2.0, and can verify that they persist in MR 2.1 as well (2.1.2.18) . Is there any chance that I could get access to the 2.2 beta?
j1n
Mar 18, 2018Apprentice
I just received the 2.1.3.2 Orbi Beta Firmware Today. After asking Netgear support if I will be notified of future Beta updates, they said that I would have to find that information out through the community boards or specifically ask Netgear support if there is an updated beta version available to download.
- bbungeMar 18, 2018Star
j1nwrote:
I just received the 2.1.3.2 Orbi Beta Firmware Today. After asking Netgear support if I will be notified of future Beta updates, they said that I would have to find that information out through the community boards or specifically ask Netgear support if there is an updated beta version available to download.Looks like they fed you a line. Next release is supposed to be in the 2.2 series like the current beta 2.2.0.30. Have no idea where they came up with 2.1.3.2 as the highest rev is 2.1.2.18
- FURRYe38Mar 18, 2018Guru - Experienced User
2.1.3.2 is a beta not posted on the support site. Users can call in and ask them about the beta.
Depending upon what comes after beta, it maybe a v2.1xx or v2.2 version. Only NG will now this.
- mpf541Mar 18, 2018Apprentice
I hope you have better luck than i did with 2.1.3.2 I got it last week and after updating and resetting my system. I had just about finished the setup and the internet dropped.
Took me 1 1/2 hours on the phone to get this. And it is not even any good.
- JMU1998Mar 18, 2018Luminary
Are all versions of the new Beta useless or is a relatively stable one available?
