AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
bbunge
Mar 18, 2018Star
j1nwrote:
I just received the 2.1.3.2 Orbi Beta Firmware Today. After asking Netgear support if I will be notified of future Beta updates, they said that I would have to find that information out through the community boards or specifically ask Netgear support if there is an updated beta version available to download.
Looks like they fed you a line. Next release is supposed to be in the 2.2 series like the current beta 2.2.0.30. Have no idea where they came up with 2.1.3.2 as the highest rev is 2.1.2.18
mpf541
Mar 18, 2018Apprentice
I hope you have better luck than i did with 2.1.3.2 I got it last week and after updating and resetting my system. I had just about finished the setup and the internet dropped.
Took me 1 1/2 hours on the phone to get this. And it is not even any good.
- JMU1998Mar 18, 2018Luminary
Are all versions of the new Beta useless or is a relatively stable one available?
- RocketSquirrelMar 19, 2018Luminary
JMU1998wrote:Are all versions of the new Beta useless or is a relatively stable one available?
I've been having pretty good results with 2.2.0.30-20180221. It's not perfect, but it's stable. I can't speak for any other beta versions.
- mpf541Mar 19, 2018Apprentice
Not sure what you have to do to get 2.2 I have been trying to get it for a while now and not having any luck. But all the other cersions I have tried don't work properly.
