AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
Starbucky
Mar 19, 2018Apprentice
Good day DerAusgewandert,
I totally agree. I did some thorough testing with one satellite to compare to the Orbi and then added the second Velop satellite last night in our upstairs hallway. Adding the second satellite took over an hour, it just wouldn't complete sinking and kept telling me to bring it closer to the router... I ended up having to basically put it right next to the router. I rebooted the entuire system a couple of times to see if my various devices would connect to their nearest satellite and they just wouldn't. I have 7 Dlink cloud cameras and they didn't connect to their nearest AP and worst of all a basement camera insisted on connecting to the second floor satellite with barely any service making it essentially non functional. As I sit at work this morning two of my other cameras aren't connecting remotely. I also have 5 Chromecast Audio throughout the house and all of them connected to the router rather than their closest respective satellites. Those are some of the stationary devices. Our phones and tablets also wouldn't roam well at all. I tried wired backhauil too and it didn't make any difference, in fact it messed up the devices page identifying all wired clients as connected to one of the satellites when they are in fact connected to a gigabit switch on the router... All said, in my case the RBK50 2pk is much better than Velop 3pk. I'm packing up the Velop tonight and re-installing the Orbi, keeping my fingers crossed that I continue to have minimal issues.
Cheers,
mpf541
I have been experimenting with a velop. So far all is working properly and I do connect to the closest node. I did notice this did take some time for this to work correctly. As the setup is all done wireless and after I moved to the correct place in my house and used wired connections. I had to renew connections from some devices to get them to switch to the closet node. Not sure if swicth while roaming i will have to test that later. But I have not noticed any problems from where devices are. There is not much roaming from room to room.
But I really hope that netgear is close to a solution for the orbi. i do have a long return policy as i got directly from linksys. Hmm that return policy is as long as netgear gives for tech support. maybe netgear should look into customer safisfaction. As I am not satified that my orbi does not work right.
