AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
Mar 20, 2018Guru - Experienced User
Getting stellar performance wired or wireless.
So i have my main router up on a 2nd story at one end of my 5000sq ft house, and the 1 Satellite in a office room at the opposite end of the house. I'd say theres 3 walls between them, same wood/drywall materials. I have two non managed switches between the Satellite and router that connects them over the back haul.
Yes I would move the Satellie farther away. Having it too close could be a cause of problems as well.
Using a Beta version. :smileywink:
Starbucky
Mar 20, 2018Apprentice
Mine's about 3500sf w/out the basement and I have both the router and satellite on the main floor. My family room and sunroom are offset from the core so I thought my current placement was best to cover the whole house (second storey and basement). Obviously the main floor gets excellent performance and the second floor and basement get good coverage. If I can get a beta 2.1.x or the 2.2 unicorn I will test wired backhaul.
- FURRYe38Mar 20, 2018Guru - Experienced User
You'll need to contact NG support and see whats up.
Let us know the results of current FW version. See if it works for you. Again you can always revert back to Wireless BH.
Starbuckywrote:Mine's about 3500sf w/out the basement and I have both the router and satellite on the main floor. My family room and sunroom are offset from the core so I thought my current placement was best to cover the whole house (second storey and basement). Obviously the main floor gets excellent performance and the second floor and basement get good coverage. If I can get a beta 2.1.x or the 2.2 unicorn I will test wired backhaul.
