AmitR
Mar 09, 2018NETGEAR Employee Retired
Orbi MR 2.1 issues update 3/9/18
Let me give you a quick update on the status since the last time we posted. Over the last several weeks, we assembled a cross functional team, locked them in a room with food and coffee and dedicate...
- Mar 23, 2018
Check out this post for an update on this issue:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
Starbucky
Mar 20, 2018Apprentice
Mine's about 3500sf w/out the basement and I have both the router and satellite on the main floor. My family room and sunroom are offset from the core so I thought my current placement was best to cover the whole house (second storey and basement). Obviously the main floor gets excellent performance and the second floor and basement get good coverage. If I can get a beta 2.1.x or the 2.2 unicorn I will test wired backhaul.
Mar 20, 2018Guru - Experienced User
You'll need to contact NG support and see whats up.
Let us know the results of current FW version. See if it works for you. Again you can always revert back to Wireless BH.
Starbuckywrote:Mine's about 3500sf w/out the basement and I have both the router and satellite on the main floor. My family room and sunroom are offset from the core so I thought my current placement was best to cover the whole house (second storey and basement). Obviously the main floor gets excellent performance and the second floor and basement get good coverage. If I can get a beta 2.1.x or the 2.2 unicorn I will test wired backhaul.
