AmitR
Mar 23, 2018NETGEAR Employee Retired
Orbi MR 2.1 Update 3/23/18
Our teams are still working through the issues, but I wanted to provide a quick update on OrbiOS 2.1. We usually wait to release our software until it's available across all Orbi product lines, but ...
henrydav
Mar 23, 2018Aspirant
Yes it does support Ethernet backhaul.
larryindublin
Mar 23, 2018Luminary
here goes nothing...
- larryindublinMar 23, 2018Luminary
larryindublinwrote:here goes nothing...
And we're back.... Not a fancy setup. Wireless backhaul. Only currently using Router and 1 Satellite until the basement is finished. uPNP turned off. Fast Roaming turned on. Otherwise default (using OpenDNS dns servers though).
Everything came back up.... Will report any stabilty issues (although knock wood, I was pretty stable and not in the "damn you Orbi" crew).
- dalnewMar 23, 2018Tutor
Update went smoothly, but my two satellites that are supposed to be using ethernet backhaul are both listed as using 5G backhaul on the RBR. A little disappointed by this. I was hoping all those issues had been resolved.
- chuahyenhuaJun 20, 2018Apprentice
hi
What is the outcome of your network for RBK53?
I have very bad performance problem
regards
chris
